Install Help
What Tools Do I Need…To Install GPS Trackers and Dash Cams?
API Signal · Install Help · Tools · Updated September 5, 2026
The right tools make the difference between a device that performs for the life of the vehicle and one that haunts the customer for the duration of ownership. This chapter is the API Signal installer kit: what's in it, why, and the tricks that go with each tool.
What are the three must-have tools for a vehicle install?
  1. Digital multimeter. Not a test light. A meter.
  2. Ratcheting crimper with wire stripper.
  3. Cordless driver with a full bit set.
Everything else makes the job faster or cleaner. These three make the job possible.
What meter or test light should I use on a modern vehicle?
Digital multimeter (DMM)
The meter tells you exactly what a wire is doing: volts, ohms, or continuity. It draws almost no current from the circuit, so it's safe on every module in a modern vehicle.
Settings you'll use:
Buy one with an auto-ranging display, a backlight, and a hold button. Dash work is dark and the meter is usually somewhere you can't see it. A set of back-probe pins for the leads lets you test inside a connector without piercing the insulation.
The one drawback: it needs two connections, so you always have to find a ground first. Keep a long ground lead with an alligator clip in the kit.
Computer-safe LED probe
A low-current LED test probe with a red light for positive and a green light for negative. Faster than a meter for hunting through a bundle of wires, and safe on modern circuits because it draws almost nothing. Most come with a cigarette lighter plug for power.
The old incandescent test light
Many installers own one. Do not use it on any vehicle built after the mid 1990s. The bulb draws enough current to trigger airbag circuits, confuse body control modules, and set codes. We do not carry them.
OBD-II code reader
Under $50. Reads and records codes before and after every install. See the Codes chapter for the procedure.
What crimper should I use for automotive wiring?
Ratcheting crimper
crimpers A cheap crimper gives a cheap install. That simple. The crimper is the tool that decides whether a connection holds for ten years or backs out in ten months.
What to look for:
For heat-shrink butt connectors, use a crimper with the wider dies made for them so the insulation isn't cut.
Heat gun
Heat shrink needs a heat gun. A lighter works in a pinch and leaves soot on the connector and a burn on the carpet. Carry a small cordless heat gun or a butane one.
Soldering iron and solder
Used less than the crimper but required for the connections a crimp can't make: a wire too short to reach a terminal, a broken lead on a plug, a diode or resistor in line. A cordless butane iron heats fast and doesn't need an outlet. Use rosin-core electrical solder, never acid-core plumbing solder.
What drivers, bits, and sockets do I need for fleet vehicles?
Cordless driver
drill Cuts install time roughly in half on fasteners alone, and you'll need the torque for self-tapping screws into metal for a ground. The one risk: too much torque strips or cracks dash plastic. Set the clutch low for interior work and finish by hand where the fastener seats against plastic.
Bit set
Carry more than you think you need:
Bit holders and extensions
A magnetic 1/4 inch bit holder makes bit changes instant. Buy a good one; cheap ones crack under torque or lose the magnet. A long extension reaches screws buried in steering column covers and kick panels. A flexible extension gets around corners, but keep it away from glass. It can whip out of your hand with enough force to crack a windshield.
1/4 and 3/8 drive socket sets
For seat bolts, battery hold-downs, ground studs, and the Deutsch connector housings on heavy trucks. Deep sockets in 10mm and 13mm earn their space.
How do I remove door panels and trim without damage?
Nylon trim tools
panel-clip A set of nylon pry tools pops clips and trim without scratching or marring. Metal screwdrivers gouge plastic and leave a mark the fleet manager will see. The forked clip tool slides behind a panel clip and levers it straight out so the clip doesn't break.
panel-use Not every panel uses push clips. Many newer vehicles use hook-and-slide retainers that pull straight up or slide sideways. When a panel won't come, stop and look up the vehicle. Forcing it costs more than the time it saves.
Window crank remover
crank Only for vehicles with manual window cranks. A forked tool that pushes the retaining clip off the crank. Still found on base-model fleet trucks and vans.
How do I pull wire through a firewall with a fish rod?
Fish rod (wire snake)
rod A stiff fiberglass or spring-steel rod for pulling wire through the firewall, behind the dash, under carpet, and along a headliner. A stiff coat hanger works when nothing else is at hand.
How to attach the wire to the rod:
wrap
  1. Lay the wire along the last few inches of the rod.
  2. Wrap tightly with electrical tape, starting at the wire end and wrapping toward the rod so the leading edge forms a ramp. Anything it hits slides over the ramp instead of catching.
  3. Leave about 3/4 inch of rod bare at the tip.
  4. Fold the last inch of tape back on itself, sticky to sticky, to make a release tab. Finding the end of electrical tape in a dark footwell takes longer than the pull.
tab If a wire snags on the way through, stop. Don't force it. Back it out, re-wrap, and try again. A snagged wire that's yanked can strip the connector right off the end, and some device connectors can't be replaced in the field.
Wire grabber
grabber A spring-loaded claw on a flexible shaft. Reaches into a hole and grabs the wire on the other side. Saves a lot of time at the firewall.
Magnet pickup and inspection mirror
For the screw that fell into the dash. You'll use it on every job.
When and how should I drill in a vehicle?
Drill bits
Drilling is rare but sometimes required. Most holes are 1/8 inch (pilot and self-tappers) and 1/4 inch (grommet pass-throughs). Carry a small set of good bits.
Step bit
One bit, many hole sizes, and it leaves a clean edge in both plastic and sheet metal. Pricey, and worth it.
Before drilling anything: look at the other side. Wiring, fuel lines, brake lines, and airbag components live behind panels. Put a grommet in every hole you drill.
Rotary tool
For cutting or notching plastic to fit a bracket or pass a connector. Use a small bit, keep the chuck tight, and keep both hands on it. It spins fast enough to hurt you and the vehicle.
What consumables should be in an installer's bag?
Electrical tape
There's a big difference between cheap tape and the good stuff. Cheap tape dries out, loses its bond, and unwraps in the heat, and the connection under it fails months or years later. We use 3M Super 33+ or Super 88 and nothing else. It's the difference between a factory look and a callback.
Everything else in the bag
What should be on the installer checklist before every job?
Before leaving the shop for an install:
Install Help
More guides
